close
broadband constantly losing connection
MrG67
dband is constantly dropping out sometimes every couple of minute sometimes longer. it is becoming very frustrating ,it also appears the wifi signal has become weeker over the last few weeks
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
