close
WiFi hun password
Danwatson795
I’m trying to change my password for my WiFi hun device. I’ve gone to http://192.168.1.1/ but it’s saying my password is incorrect and won’t allow me to change.
What pwd are you using to login?
Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the password found under the battery cover. Then on the WiFi Settings tab you should be able to see your WiFi password in clear & change it if you like.
