close
Wi Fi weak spots
Alanmiff1974
There are some flat spots upstairs for WiFi. Does EE have any signal boosters for different rooms
Have you considered WiFi Extenders ? They carry the signal over your mains electricity.
mikeliuk
Hi @Alanmiff1974 ,
The above is good advice. Please see the below link to help you select the best option.
Personally I recommend powerline adapters (plus WiFi access point away from router) over WiFi extenders, and the Devolo brand is a very good choice. Other brands are available.
(Powerline adapters use electrical wiring to carry data and this is different functionality from a WiFi access point. Many powerline adapters do not have the additional WiFi functionality.)
What is a wi-fi extender? A wi-fi extender (or wi-fi booster) is used to amplify and repeat the wireless signal from your router to expand its coverage. It helps to rebroadcast the signal to where the wi-fi may be weak or non-existent.
https://www.which.co.uk/reviews/wi-fi-routers-and-extenders/article/which-wi-fi-router-or-extender/w...
An example of a WiFi extender is https://shop.bt.com/products/bt-11ac-dual-band-wi-fi-extender-1200-080462-B15P.html
@mikeliuk : WiFi extenders include Powerline adapters.
