close
Why cant i use my data as hotspot?
Can5935
I would like to use my 60GB data pack as a hotspot but it says encrypted and i cant connect my other devices to my EE phone. Can you help me please?
6 REPLIES 6
Jon_K
Former EE Employee
Hi @Can5935.
Welcome to the community.
What phone are you using?
Do you have a password set up?
Jon
@Can5935   You can use your data how you like. This includes using it via hotspot.  You should just be putting the passcode in to connect to your device hotspot.
I use casper via f1, yes set up the passport. When i try to connect hotspot, it say encrypted.
Change your Password in Hotspot Settings.
How To, here -
https://www.devicesfaq.com/en/share-internet/casper-via-f1
Hi @Can5935
You cannot have entered the password correctly.
mikeliuk
Hi @Can5935 ,
What device gives you the error "encrypted"? This doesn't make much sense as a connection made to a properly secured hotspot will be encrypted.
If you have two mobiles to test with, can you put the SIM in the other phone and establish a hotspot on that other phone instead?
Just as a sanity check, are you able to access news.bbc.co.uk simultaneously as you have setup the hotspot?
