close
VPN on Smart Router
Mortimer
I have just received a Smart Router which hasn't been installed yet. Previously I had a Bright Box.
I would like to know whether it is possible to install a VPN on the new router, I use ProtonVPN>
Hi @Kirigaya_Kazuto ,
I think that, broadly speaking, what you have said is correct and users may refer to https://protonvpn.com/support/categories/setup-and-use/ to do this.
The service provider's router is unlikely to be a suitable initiating device on the service provider's or stock firmware.
8 REPLIES 8
Kirigaya_Kazuto
Star Contributor
Star Contributor
Yes, there should be no reason why a outbound VPN would not work
mikeliuk
Hi @Mortimer ,
It sounds like you want to establish a site-to-site VPN connection and this is almost certainly not going to be supported by any of the service provider's routers using their stock firmware. In particular, it's unlikely that any of them will support or provide an OpenVPN server which the ProtonVPN documentation (below) says is required.
Please refer to https://protonvpn.com/support/installing-protonvpn-on-a-router/ to see a list of the routers you may choose from.
For other just browsing this thread, they may take a peek at https://protonvpn.com/blog/setup-a-vpn-router/ to understand the context.
Thanks for your help  .
I'll look into getting a different router
Did this VPN work thro' the BrightBox? If so, there's no reason for it not to work thro' an EE Smart Router.
I think you've misunderstood my question.  I don't want to have it go through the Smart Router, I wanted to know if I could install it on the Smart Router.  That question was already answered but thanks for taking the time to respond.
That's right, you can't install a VPN on an EE Smart Hub any more than you could on a BrightBox.
Your Q implied that you had previously done this with a Brightbox, which is impossible!
I dont think it did. I merely said I had been using a Brightbox. If it had been possible to install a vpn on that it's unlikely that I would ask the question in the first place as the Smart Router is supposedly superior.
Anyway the matter is now closed and there is no need to reply further
