close
Upgraded twice? What happens?
Bort
so, yesterday I upgraded to the new iPhone 12 pro, received an email saying they’ve got my order. But shortly after I decided I wanted a different package, one that had 1 benefit instead of 3 to save money. The upgrade option still come up, so I went ahead and placed a new order. Would this replace the previous order I had placed as I technically shouldn’t be able to have both of them as I’m upgrading 1 device. Just a bit worried I’ll receive 2 phones somehow. Also on the upgrade I got in the end, the tracking number doesn’t work
Schockwave
Hello @Bort ,
Welcome to the community,
I would suggest you ring customer service to make sure that you’re order is for one new IPhone and that you just wanted a change to your package, they will be able to look into this. If you do receive two of them, you can then ring them up and ask for a return label to return it for free and any money you have paid etc will be refunded on the next bill, depending when your bills come out, just make sure that it is the correct one with the correct plan, although ringing customer service to check, is the best and simplest option..
Was the tracking number xko.... number, then that is just your order number not the tracking number?
Schockwave
Hello @Bort ,
