close
Upgrade phone but keep plan
blueboy1971
Hi All
I have the upgrade option showing but there does not seem any way to upgrade just to a new phone but keep my plan.
I also work for NHS so get discount so need to roll this in as well.
Live chat does not seem to be working and i would rather not talk on the phone as prefer everything discussed to be documented.
Hi @blueboy1971
Welcome to the EE community
When you upgrade a phone through EE, you choose a new plan to go with it - you can't keep your existing plan.
As part of the checkout process, there should be an option to insert discount codes - which you must do at the time, and cannot add retrospectively.
