20-09-2021 04:37 PM
I am trying to upgrade my sim only contract to a handset contract on the new iPhone 13 pro. However it is automatically applying a small upgrade discount which is preventing me from using the friends and family discount code. Is there a way to disable the upgrade discount to avail of the f&f code?
20-09-2021 04:49 PM
Hello @smccarter86.
What discount is being applied?
Speak soon,
Katie.
20-09-2021 04:58 PM
Hi Katie, I'm not sure what it is for as it just auto populates.
20-09-2021 05:05 PM
Yeah it's a loyalty/renewal discount. I also wondered if I could get this removed to use my F&F discount on the smart plan.
20-09-2021 05:07 PM
Thanks for getting back to me @smccarter86.
I would recommend checking for any previous discounts which may carry over.
If this is loyalty discount @ScaryGrant you can call our customer care team who can help remove this so you can use your Friends and Family.
Katie 🙂
20-09-2021 07:20 PM
I rang through to customer services and no one seems to know what the discount is or how to remove it. I’m stuck now not being able to remove it from my line or use my f&f code. Any ideas what to do next?
21-09-2021 08:20 AM
Hi @smccarter86.
If there doesn't appear to be a discount on your account, you could try contacting our Upgrades Team to see if they can manually complete this for you including your friends and family code.
Jon
21-09-2021 09:32 AM
Hi Jon,
I’m having the same issue, there is a discount applied to my account on smart tarifs, which means I can’t use my f&f discount. I called already and they can’t put the f&f discount through online anyway, could you look into this for me by any chance?
thanks
adam
21-09-2021 11:28 AM
Hi @ScaryGrant.
Were you able to speak with our Upgrades Team over the phone?
They may be able to manually add this for you.
Jon
21-09-2021 11:29 AM
I did, and they are unable to. F&F discount has to be put through an online checkout, but I can't remove the automatic discount that is already being applied in order to add the better discount.
