close
Strict NAT type in COD Warzone
camy252
Ive been given a heads up about 4GEE's non static IP and CGNAT situation but I've been able to get NAT type 2 on my PS4 and had no match making issues in games so far. I've also been playing other PC games without port blocking/nat issues so I was bit disappointed to see my nat type as Strict in Warzone.
The game was free so I promised myself I wouldn't get too wound up about it and then spend weeks troubleshooting. But I'm really keen to play this and I'm also starting to worry about future games.
Is there a way to fix this? I understand EE doesn't allow for port forwarding? And even if it did, I'd have to disable Unpnp? Which I suspect is the reason all my other games work fine as its doing its job right?
The confusing bit is not having nat issues with my PS4 and other pc games but having it in warzone. Surely if it's my IP address and EE then any devices downstream of my router would be having the same issue?
Christopher_G
Hi @camy252
Another user on a different thread mentioned changing manually from IPv6 to IPv4. That seemed to resolve it for them.
Could you give that a try, if possible?
camy252
Hey Chris, thanks for the reply. Already have Ivp6 turned off as that was causing problems when I first installed my router (video calls not working and emails not sending).
Tested warzone again last night and randomly my nat changed to moderate. I was also able to play with 4 mates without issues so thats a good sign. Wondering if that was just because they are all on open nat or my upnp feature is doing its job.
Had this problem myself using phone as a hotspot, don't know about PS but on Xbox go to network setting -> advanced settings -> alternate port selection -> manual -> and keep changing ports until it's not strict, I got moderate may this way, sadly couldn't get open.
Though it didn't change my NAT settings I found changing my dns settings on my xbox (network advanced settings. Dns manual. 8.8.8.8 / 8.8.4.4 allowed me to play perfectly cross platform.
Hope this helps.
