close
Samsung s10 5g
Akhlasb
  • I'm on a Sim only 5g contract.
  • No software updates showing on my device despite Samsung saying it rolls out in June 2021.Have an unlocked device purchased from music magpie nearly 12 months ago
Hi @Akhlasb
Apologies for the delay in my reply.
You have the generic UK firmware. Very strange that it doesn't update. Did you try clearing the cache as I've suggested?
If that doesn't work then I would suggest backing up and then factory resetting via recovery. Then trying to update.
6 REPLIES 6
mikeliuk
Hi @Akhlasb ,
This sounds like a case of waiting for the over-the-air firmware update to become ready for your Samsung device. I believe there is nothing that EE can do about this if they did not supply your device.
If your Samsung device is a never-locked device, you can approach Samsung to check when the over-the-air update will be ready. If it was previously locked to a different network and was unlocked, you may need to do some checks with Samsung on which over-the-air firmware it will move to next. Good luck!
EssexBoyEE
Music Magpie, the phone could have come from any part of the Planet.
Under Manual Check if it says, after checking, your phone is up to date, that's it, no more you can do.
Northerner
Hi @Akhlasb
Enter *#1234# and post the three sets of numbers.
What is the last security patch you have installed?
Lastly boot into recovery and try clearing your cache, then restart and try software updates. (On WiFi)
@Northerner @
AP G977BXXU2BSL2
CP G977BXXU2BSK0
CSC G977BOXM2BSL3
SECURITY PATCH DEC 2019
ANDROID 10
UI 2.0
Hi @Akhlasb
Have cleared cache but phone is going back under warranty for a battery issue. Will ask them to try update.
Thank you
