close
Samsung Q60R
max617
Hello please could someone help.
I have got the Samsung Q60R TV as a add on and it has stopped working, it won't connect to the internet/network,
I have reset everything, also no TV channels are found and there is nothing wrong with the Arial.
Please help.
Stephen
Hi ya,
I have signal on other TVs that I have checked on the Arial that the Q60R is on,
And the WiFi is connected on other devices.
Called Samsung and they have no idea and to call a engineering out even though it's under warranty.
Think this is shocking as I pay for it monthly.
Error message is er4001
12 REPLIES 12
Katie_J
Hello @max617
I am sorry to hear this has happened.
Can you confirm if you are receiving any error messages?
Do other devices in your household connect to the WiFi OK?
Katie 🙂
Hi ya,
Hi ya,
Katie_J
Thanks for letting us know @max617
Please could you keep us updated with the outcome of your engineer visit?
Katie 🙂
The engineer has just left (£50 I didn't need to spend) just to say the signal is fine from the Arial but it's a faulty TV as it's not receiving the signal,
Now I have a TV that's usless
Katie_J
Hi @max617
Did the egineer advise for you to get back in touch with Samsung as you are under warranty?
Katie 🙂
Just called Samsung back and now they are saying that as I got it form you I will have to deal with you
Katie_J
Hi @max617
Please give us a call and report this to our technical care team who can take a further look into this.
Katie 🙂
What number should I use
