Samsung A21s mic not working
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
22-03-2021 08:29 AM
Hi all, first time poster. My main mic isn't working so I am reliant on speakerphone or video calls at the moment. I've cleaned the mic and done all my updates but alas nothing doing. Any suggestions folks? Thanks in advance! R
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
22-03-2021 09:05 AM
Hi @Raisins1
As a first check, have you restarted your phone?
Do other apps that use the bottom mic (I believe this includes voice recorder) work ok?
You might need to consider a full backup of all your data, and factory reset - in order to indentify whether this is a hardware or software issue.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
22-03-2021 09:25 AM
Thanks Bristolian. Yes I've restarted a few times. Voicerecorder doesn't work. Was hoping to avoid a factory reset but I think I'll have to accept it and give it a whirl!
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
22-03-2021 10:13 AM
Hi @Raisins1
If you can try this after backing up all your data, and let us know if this resolves the issue for you?
Thanks 🙂
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
22-03-2021 10:38 AM
Before factory reset, worth trying to boot into "safe mode", then give the microphone a test?
Also maybe worth trying another microphone recording/tester app too just in case, while in normal mode too?
Unless you have tried all this.
