| For up-to-date information and comments, search the EE Community or start a new topic. |
14-10-2021 01:45 AM
Hi for some reason my hotspot doesn’t show up on my tv I have a Samsung tv and a iPhone 13 it used to work when I had my XR but no it’s not working?
14-10-2021 08:30 AM
Welcome to the community.
Have you tried resetting your factory settings on the iPhone?
Tap Settings > General > Reset > Reset Network Settings.
14-10-2021 08:31 AM
Make sure your phone is viewable and refresh the network search on your Samsung TV.
28-11-2021 06:48 PM
Hi I have an IPhone 11 on EE and it won’t connect via hotspot to my Samsung Smart TV. It’s shown on the network list. It allows me to put the correct password in and then just shows little red crosses on the network connection.
I’ve reset the network settings on both the TV and the phone. My girlfriends phone connects straight away, hers is iPhone 12 on o2
any ideas guys ??
29-11-2021 08:06 AM
Hi @MrG73
Can you connect to any other device?
Speak soon 🙂
29-11-2021 12:21 PM
Hi Leanne Yes I can connect to other TV’s and wifi devices no problem.
it’s not the TV as a I said my girlfriends phone connects to it no problem.
any solutions? I’ve restarted it. I’ve refreshed network settings on both devices
thanks
Scott.
29-11-2021 12:32 PM
Thanks @MrG73
I would suggest giving us a call on 150, and the team will run through some troubleshooting with you.
Let me know how you get on.
Leanne 🙂
