on 19-04-2021 09:35 AM
My SIM card is not working anymore and I can't find a reason why. I can't find anyone from EE to help me with some info. Not emails not nothing. When I try to add any pack from the website it says only : try again later.
on 19-04-2021 11:16 AM
Hello @Flaviu1234
Is your SIM a PAYG one, or a pay-monthly?
You've referred to packs, so I would assume PAYG - have you not used the SIM for a while, it could have been hibernated due to non-usage. If that is the case, you can read about the policy on this EE help page
on 19-04-2021 12:31 PM
@Flaviu1234 : Sounds like it has gone into hibernation.
When did you last use it for a chargeable action? EE PAYG SIMs are deactivated after 6 months of non-use. You then have a further 3 months to call EE to reactivate it before it is lost completely.
You needed to make a chargeable action like making a chargeable call or text, topping up or buying a Pack or Add-on, not just using your mins, texts or data from your pack.
on 19-04-2021 03:08 PM
I tried calling the number of customer service at EE all day but it says it is not in use. Is there any other way to get in touch with them ?
19-04-2021 03:37 PM - edited 19-04-2021 03:38 PM
Hi @Flaviu1234,
When was the last time you used your SIM?
Which number are you trying to call?
You can find contact numbers for Customer Care at ee.co.uk/help/help-new/get-in-touch.
on 19-04-2021 04:58 PM
From there I took the number. This number : +44 800 079 8586
Well, I used my SIM monthly, but just receiving calls, not making calls. But the SIM was used I would say
on 19-04-2021 05:07 PM
on 19-04-2021 05:09 PM
Pay as you go
on 19-04-2021 05:14 PM
Hi @Flaviu1234,
When was your SIM last used for a chargeable activity?
Chargeable activities include:
on 19-04-2021 05:16 PM
Around September or smth like that. Why ?
