close
Re: Downgrading broadband package
LesleiM
What is the minimum period for the contract... I have a 18 month since May 2021 on a 300 max Fibre £50pm, but in reality the BT connections only give us a max of 70MB... This is what the engineer told me at the time of connection, can I downgrade without the penalties as the service I've purchase cannot be delivered?
Speed test:
Ping 7
Jitter 5
download 65
upload 42
Thnxs,
Paola
@LesleiM : Welcome to EE's Home Broadband Forum.
The min. contract term for new contracts is 24 months.
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
