24-06-2021 08:17 PM
My pay monthly contract ended today and I switched to pay as you go, now all incoming calls say private number. How do I stop this
24-06-2021 08:34 PM
Hello @Col1y
Welcome to the community
The instinctive response is that those callers are not sending their number, and you will need to ask those callers to release their CLI. This is based on there being a difference between "Number withheld" (which you've explained) & "number unavailable" (which indicates broken CLI somewhere)
If you are sure that all calls, where CLI should be present, are not showing their number on your phone, there may be an issue with your SIM/account related to the transfer. You should call EE C/S on 150 (from your mobile) who should be able to rectify this.
06-08-2021 08:31 PM
I got the same problem in the same situation.
All calls is showing private number.
Someone solved?
06-08-2021 09:04 PM
06-08-2021 09:13 PM
Thanks! I'll try this.
