close
Phone use on wifi
ronecc
Does EE support wifi calling? I live in a poor reception area and with my current supplier, I can use my wifi if I need to call.
I notice that EE does not support wifi calling on PAYG. My current supplier does. When will EE join the club? My phone supports it.
6 REPLIES 6
Kirigaya_Kazuto
Star Contributor
Star Contributor
New and existing customers on EE pay monthly plans and existing small business customers can get WiFi Calling if you have a compatible device. It's not available on pay as you go right now. WiFi calling is available to all corporate customers on a 4GEE plan with a compatible device.
Thanks for your reply. Yes I did find it is not available for PAYG customers. My second question was basically, why not? 3 can do it, so why not EE, I thought you were 'the best', or so your tv adverts say.
Also why is it so difficult to find how much you charge per minute, for a PAYG customer, to make a call.
As I stated, I live in a poor/none reception area and just need a phone that will work on wifi. Unfortunately 3 have their foibles as does EE by the sounds of it.
  1. 35p / min call to UK no.
  2. No WiFi Calling on PAYG.
Three & EE are different network operators. EE's 4G & 5G networks do indeed have much wider coverage, and generally perform better, than that of Three.
There's many additional services that EE offer, that 3 don't.
In the case of 4G-calling & WiFi-calling, there are legitimate technical reasons why EE PAYG customers don't currently have this facility.
@ronecc   While EE don’t offer WiFi calling on PAYG do they have a good network reception in your area as you say 3 doesn’t so would you need WiFi calling ?  Every network has pros and cons and your case 3 has WiFi calling on PAYG but a poor signal in your area.  EE doesn’t offer WiFi calling on PAYG but what’s the signal like ?
What are they? It's just a SIM with a plan. Other networks manage it with the same technology. Or do you mean commercial reasons?
