close
Pac code error
vadimc1992
hi i am a new customer EE and I want to port my old Giffgaff number to EE but I am having a problem ( Please make sure you enter the right code. Your PAC will look like ABC123456. Your STAC will look like 123456ABC.) Sorry my english is badly and i use google translate
6 REPLIES 6
Hi @vadimc1992
If you're having problems submitting your PAC online, I would recommend calling EE C/S on 150, and giving it to an agent over the phone instead.
I speak English badly, I will not be able to call
Unfortunately there is no access to individual customer accounts on this public web forum. If you are unable to call, I can only suggest rechecking the PAC that you've been given by your previous provider, and try the online form again.
What's the problem? Doesn't it look like the form says it should? If it doesn't you will need to go back to GG to check it.
I entered the correct PAC code but the form gives an error
Jon_K
Former EE Employee
Hi @vadimc1992.
Is your PAC made up of three letters followed by six numbers?
If you're still having trouble, are you able to use our online chat service?
Jon
