27-05-2021 03:59 PM
I've just been given an Osprey Y855 and it has firmware version Y855_E1_01.11_09 on it which I understand is the factory release. I've been told that there is a newer version available which is more stable, but when I click the Check for Update button on the router web interface, it doesn't update. It comes up with a box saying Version Information Checking, and after a minute it then says Error.
I've done a reset both in the interface and by the Power + WPS method but it still won't work.
Is there any other way to do an update? Is there a firmware file for it that can be uploaded to it?
Andy
30-06-2021 09:28 AM
I've not updated mine for ages, and only use it periodically - thought I'd try and update it today as vulnerabilities are found all the time, and also got the error message.
Did you get it sorted?
Thanks, Nick
