close
No SIM card
AnnaDB
Hi I keep getting a message saying my SIM is not working. Restarting doesn't help. Nothing wrong with the network. Massively long queue on 150 and I can never get through. My phone is basically useless. What do I do? Thanks, Anna
7 REPLIES 7
@AnnaDB  take your Sim card out of your device and give it a clean with a damp cloth make sure it’s dry before you put it back into the device.
Hi Chris, thanks, I've done that but nothing seems to work. Occasionally the phone does work but 90% of the time it doesn't, and it's getting worse and worse. It's really annoying. Thanks though!
Katie_J
Good Morning @AnnaDB
Are you able to try your SIM in another device to see if this continues?
If it does, I would recommend a replacement SIM.
Katie.
Hi Katie, I've tried everything. I can't get through to EE on 150 and the site says I can't order a replacement online, so how can I get a replacement SIM? Many thanks, Anna
Katie_J
Hi @AnnaDB
Our phone lines are still open, please continue to hold past the automated system and a member of our team will be with you as soon as they can.
The team will then be able to help order your replacement SIM :),
Katie.
Hi Katie, I've waited over 25 minutes twice now, and have never managed to get through to anybody. I can't really afford to spend more time waiting. Thanks, Anna
Katie_J
Hello @AnnaDB
I have sent you a private message, please take a look and get back to me.
Katie 🙂
