My 4g mini hub stops working after about 10 minutes
JohnMorgan1
My mini hub just keeps cutting out after 10 or so minutes of use.
There is still data, I've not run out.
The battery is at 80%.
I have it where situated where it can get 4 bars.
Starts out fine, then after about 10 minutes just cuts out.
Red flashing light.
I can't connect to reset it.
I need to power it off. leave it and try again later.
Very annoying, it's cut out in three meetings this week.
What is the problem, please?
7 REPLIES 7
Christopher_G
Hi @JohnMorgan1
Welcome to the community.
How long have you had this problem for? Could you please check your postcode on our network status checker please?
Hi Chris,
I've had the hub for around 6 months, but only started using it regularly.
The area I'm in has 5G coverage.
Christopher_G
OK thanks, @JohnMorgan1
Could you check the 'network' button on there, just to see if there are any maintenance works in your area?
Hi chris,
I've done that. it says no know work in my area.
John
Christopher_G
OK, thanks for checking, @JohnMorgan1
Does anyone in your household have an EE mobile phone? If so, are their mobile internet services working OK?
I have an EE mobile and that works just fine.
Christopher_G
OK thank you, @JohnMorgan1
I've sent you a private message to get some information from you. Please have a look and get back to me.
