close
Mobile Data not working.
randomusername3
Last year I was easily able to use my mobile data normally without any problems. Now whenever I buy data, it's very unreliable and doesn't seem to work at all.
Yesterday I bought a 100mb pack. I activated my mobile data, still couldn't use online apps, and I still have 100mb of data left which I can't even use.
@randomusername3 : 100 MB? That's not much! You sure of that?
Can you make calls & texts?
What does texting AL to 150 from it fully report verbatim (it is free)?
When did you last use it for a chargeable action? EE PAYG SIMs are deactivated after 6 months of non-use. You then have a further 3 months to call EE to reactivate it before it is lost completely.
100MB is enough for what I need it for. And yes, I am sure. The data didn't work at all, hence I still have the full amount on my account.
Yes I can make calls and texts, I did so a few hours ago.
I texted AL to 150. It says the following:
"Your current balance as of today 23:37 is £12.93. You have 100MB remaining until 01/08/2021 for your 100MB 7 day add-on. Your last top up was £10.00 on 11/11/2020 at 15:27.". And yes, it was free.
I made a chargeable text today, and bought the add-on yesterday, as previously stated in my original post.
Are you in UK?
Yes I am.
Hi @randomusername3,
What happens when you try to open a web page in your web browser?
