close
MIFI yellow box
paulfenn
My MIFI keeps turning its self off during down loads or zoom, and i have to re start it.
Any ideas? Have tried factory reset.
6 REPLIES 6
Jon_K
Former EE Employee
Hi @paulfenn.
Is the box connected to power when you're doing this?
Does it happen every time?
Jon
Yes its connected to power.
It seems to only do it when in heavy use, simple things like emails and web sites ok, but online data platforms, teams and zoom effect it, it doesnt loose signal, it just powers off.
Katie_J
Thanks for confirming @paulfenn
Have you reported this to our technical care team?
How many devices are connected when this happens?
Katie.
Only two devices connected.Cant find anywhere on EE site for Technical care!!
Katie_J
Hi @paulfenn
You use the online chat service which can be found on our get in touch page or call us on 0800 079 8586 from any landline or provider.
Katie 🙂
EssexBoyEE
How old is it, could be the Battery has degraded and is forcing the Router to do strange things.
If the MiFi is permanently on charge it probably will kill the battery over time and with age.
