London underground wifi
the-tang-family
I'm on EE and have tried to connect to the TfL network (EE WiFi-Auto).  However I get this screen:
Anyone have any ideas what I need to fill in? I have redownloaded my network settings, and still get this screen (android phone)
354-
Star Contributor
Star Contributor
Yeah I've read this, but doesn't give me any of the info that I need...
Leanne_T
Hi @the-tang-family
Thanks for posting on the community.
WiFi on the London Underground is provided by Virgin Media, are you on the underground when trying to connect to WiFi?
Thanks.
Hi @Leanne_T
Yes this is when I am on the underground trying to connect to the WiFi. I know the old network was the Virgin-named one, and it directs EE customers to connect to EE Wifi-Auto. But the pic in the original post is what comes up on my phone (android) whenever I select it?
So if someone from technical could advise what I need to stick in all the fields, that would be great!
Leanne_T
Hi @the-tang-family
Thanks for the quick reply.
The only details you should need to enter are below:
  1. set the ‘access method’ to EAP
  2. set your ‘EAP method’ to SIM
If this is not working, please give our Tech Gurus a call on 150, they will get this looked into further for you.
Thanks 🙂
