| For up-to-date information and comments, search the EE Community or start a new topic. |
05-08-2020 09:41 AM
Hi guys, I cannot find LTE settings on my Iphone 6. Any ideas?
Apple instructions don't work - cannot see any reference to LTE
On your iPhone, go to Settings > Cellular > Cellular Data Options and tap Enable LTE or Settings > Mobile Data and tap Enable LTE. If your carrier supports Voice over LTE (VoLTE), you'll see these options:
05-08-2020 11:05 AM
Actually @Jimboaloobob it's the opposite.
EE used to provide a "Signal Box" that plugged into your home broadband and acted as a mini-3G-cell where you otherwise had no coverage.
Those signal boxes are now old technology, and WiFi-calling is the recommended coverage solution anywhere that you don't have mobile coverage.
EE also have "extended-range" coverage that (where it's available) can improve 4G coverage in rural & indoor locations, but you need to have a 4G-calling device on a pay-monthly plan to be able to use that. And if you disable 4G, then you would lose access to that.
05-08-2020 09:53 AM
Why would you want to disable 4G or VoLTE?
It improves your service and also unlocks access to EE's extended-range 4G coverage that isn't otherwise available.
05-08-2020 10:42 AM
05-08-2020 11:05 AM
05-08-2020 11:10 AM
