close
Is my white 'Smart Router' on 5Ghz or 2.4Ghz? I bought a smart light ....
JYoung2
I bought a smart light that needs to be on 2.4GHz, but I don't know how to check if my router is on 2.4 of 5Ghz. How would I change this on router? I've been going round and round in circles online.
I'm a new EE customer, and I have that white 'Smart Router'. Can anyone help??
I d/l the EE Home app and there's not much you can do there.
It's on both! With the Smart Router there's no way of telling which you are connecting to unless you disable 1 of the bands.
Beat way to try is to disable the 5GHz band, connect the 2.4GHz device & then reenable the 5GHz band.
JYoung2
I have the same issue, I have a light that needs to be on 2.4GHz, but I don't know how to change this on router and I've been going round and round in circles online.
Had same issue, how do you disconnect 5g then connect again? Please advise thank you
@JYoung2 : It's all on the Advanced Settings > Wireless Settings page.
