19-02-2021 04:59 PM
Have just bought a new Iphone 11 that has dual sim capability. I have a nano sim and an e-sim in the phone. One is my private number one is my work number.
I have no mobile signal at home and wanted to check if anybody knows if both the sims (so both numbers) can have wifi calling at the same time so I can receive and make calls on both lines.
Have had some conflicting responses from Apple helpdesk.
Thanks,
19-02-2021 07:04 PM
@Wascum Are both numbers on EE ? If not does the none EE number have WiFi Calling from that network enabled the account.
19-02-2021 07:04 PM
19-02-2021 07:22 PM
19-02-2021 10:46 PM
@Wascum It should work as WiFi calling is just another way to receive a working signal on your device.
