| For up-to-date information and comments, search the EE Community or start a new topic. |
25-08-2020 04:46 PM
Hi
I have a new iphone 11 Pro Max (had a few weeks) and it has started to reboot at random times.
I can not find out any advice to work out what is causing it and what to do.
Any help would be gratefully appreciated.
So far I have
1) Manually rebooted.
2) Uninstalled the last apps I recently installed
3) Checked on latest version of IOS
Thanks All
David
25-08-2020 08:56 PM
A while back I had this problem. I contacted Apple Support who advised me to remove all but the included apps and see if the problem still happened. It did, so they then arranged for a replacement iPhone.
Has you have done some other things that I would have suggested, I would get in touch with EE and see if they will replace the iPhone.
If you get no joy from EE, I would get in touch with Apple, as Apple handles warranty for their phones.
