03-10-2019 01:08 PM
Looking at ordering online and getting delivered to my house.... Is the sim card already in there with my current number on ? I'm doing a phone/SIM contract on Samsung A70
03-10-2019 01:22 PM - edited 03-10-2019 01:23 PM
Hello @nicoleallison34 ,
Welcome to the community,
Yes, you set it up yourself. If you are a new customer and not had a SIM card from EE, then you will receive a new SIM card with instructions how to activate it, but if you already have a SIM card with EE and are using the same number, then you can just put your SIM card in the new phone and set up your phone yourself.
If you have another phone with all your contacts, photos etc.., you may want to back them up, so that you can put them on your new phone.
You may also want to download the guide for your phone, which should give you plenty of help.
03-10-2019 01:36 PM
Do you know how long it takes to deliver?
03-10-2019 02:03 PM
@nicoleallison34 , You should receive updates when the phone will be delivered, once you have a tracking number you can track it, but it also depends whether the phone is in stock.
03-10-2019 02:22 PM
When would the new contract start?
03-10-2019 04:51 PM
Hi @nicoleallison34.
The contract would start on the day that the phone is sent out to you.
If it's a brand new line, it would be from when the SIM card is activated.
Jon
