close
How to find what I I’ve used on WiFi dongle and link to my account
Jessiej
@Jessiej : Look at http://add-on.ee.co.uk/status from a device connected to your mobile router by WiFi to see your data & credit status.
What @XRaySpeX says, but this will not work for you if you have an Unlimited Data Plan. If UL your need to set the Router/Dongle,s own Data Tracker to coincide with your Monthly Allowance Refresh Date.
@EssexBoyEE : The Status page does give your usage this billing month even if unlimited.
@XRaySpeX not on Mobile Unlimited  Data Plans, it just gives you your Data Allowance not the Usage, App and Web Login is the same. Which Ive found a bit ironic that EE have one of the lowest FUP on Data use but don't give your usage details.
It's the same as the older UL Mobile Data Plans from around 7  or 8 years ago only gives your Allowances
