close
How do I request PAC code for one of my other lines?
ShahHamzah
I have 3 other lines with my account. Hoe do i request pac code for one of my other lines? It keeps saying "your not the account provider".
If i send the text with my number it gives me the pac code for my number. But i dont want my numbers pac. I want it for my brothers number.
You will need to call CS for your PAC. You can't text for a PAC when you have a multiple a/c.
Profile closed
Not applicable
Hi @ShahHamzah
If you log into MyEE click on account settings on the left hand side then click switching > switch from EE > get your switching code > select the number you wish to move > then your PAC code will be displayed.
Thanks,
David.
@XRaySpeX   thanks for the info
I was amused by your sign off.
I thought if you add the cost  for each of you data connections,,, that woul dbe amusing !
