22-05-2020 01:10 PM
Hi
How do I report a fault with my landline phone ?
It is so frustrating I have been driven around in circles
09-10-2020 03:52 PM
P.S.: My partner is in the same category as your father, and yet ...
09-10-2020 03:53 PM
PPS - I have of course attempted testing with test / master socket! (should have mentioned that)
09-10-2020 05:54 PM
Hi @lomekian
Welcome to the community.
I'm sorry to hear that you've had some problems getting through.
I've sent you a private message to get some information from you.
09-10-2020 10:17 PM - edited 09-10-2020 10:20 PM
@lomekian wrote:
I've been spending an age getting nowhere on the 150 system for my BT broadband landline.
You should be reporting that to BT not EE. Unlike EE, BT has a superb online reporting & monitoring system for landline faults.
You probably have a "one-leg broken" fault (technically "HR Dis"). A landline consists of 2 wires, both of which are need for voice, but only any 1 for BB. Usually when this happens the BB runs slower than usual.
It is likely that the break occurs between you & the exchange, but it needs your landline provider to call out BT Openreach to fix it.
28-11-2020 04:15 PM
Not that I'm an expert by any means ... I've just tried to ring you - getting a ringing tone but no reply; I presume it isn't ringing your end.
How sure are you that it's the line and not the telephone itself?
28-11-2020 04:35 PM
@Firefox1701 : The probability I mention above. It could be your handset. Have you another to try?
I don't receive calls on my phone from this Community.
28-11-2020 05:39 PM
I don't know if any of these replies are aimed at me, but the issue has been resolved now for my father.
I don't know how the others are getting on - and thanks to the earlier EE representative who sent me a PM
Matthew
15-10-2021
09:23 PM
- last edited on
15-10-2021
10:57 PM
MikeT
I have fault with my landline xxxxxxxxxxxx
[Mod edit: Please do not share personal details as your posts are visible to the public. Thanks!]
15-10-2021 10:01 PM
@060643 This is a public forum, you should not publish your phone number as it may attract all sorts of unwanted attention.
Have you reported the fault to CS? - Details are available in the earlier posts.
15-10-2021 10:40 PM
@060643 : Try texting HELP followed by your landline number to 60071.
