19-06-2020 01:59 PM
I am going overseas for quite some time, and taking the roaming package to use my UK number. Destination is Asia, and hence not covered by the EU coverage. But most importantly, how do I get a replacement SIM card if I lose or damage my current EE simcard?
20-06-2020 06:41 PM
@hazlee Yes. A sim will only be sent to the billing address.
19-06-2020 02:10 PM
@hazlee if you was to lose your Sim card whilst abroad you would need to call customer services and request a replacement Sim card that Sim card will be sent to the billing address. The Sim card would need to be activated before someone at that address can post it to you.
19-06-2020
02:15 PM
- last edited on
19-06-2020
02:47 PM
DanielPA
19-06-2020 03:00 PM
Sorry. I accidentally marked your resoonse as the solution. Can you aanswer to my last query? Thanks.
20-06-2020 07:12 AM
Hi @hazlee,
Are you using a pay as you go or pay monthly plan?
20-06-2020 07:20 AM
@hazlee To activate a sim it just needs to be put in to a device until the device shows a signal. When it does make and receive a call to check all is ok and that’s it. ( your number should be on that SIM card ) It usually takes 4-5 hours to activate,
20-06-2020 06:24 PM
It is pay monthly.
20-06-2020 06:26 PM
And regarding the sending of the new simcard to the billing address - should I change it to my relatives' address instead in the meantime before I move back to the UK?
20-06-2020 06:41 PM
04-12-2020 08:47 PM
I’ve lost my sim card, how do I get replacement sim ?thanks
