Flashing aqua light on router
Lurch180
My activation day for my broadband was yesterday and I've had the confirmation text and email. Connected everything correctly and the router has been flashing aqua ever since, I waited until after midnight and still no luck, do I have to wait a bit longer or is there something wrong?
6 REPLIES 6
Christopher_G
Hi @Lurch180
This light usually means the internet cable isn't connected properly.
Could you check to make sure it's all plugged in?
How to set up your Smart Hub >
@Christopher_G  Thanks for the reply! Everything’s plugged in properly yeah
Flashing Aqua means there's no BB yet. Just wait or call CS.
@XRaySpeX Thanks! I’ll wait until tomorrow to see if it connects and if not I’ll give them a call 👍
My box is flashing aqua I've disconnected everything and it's still flashing aqua can anyone help me with this problem
Jon_K
Former EE Employee
Hi @Sharlene3.
Welcome to the community.
Can you check that the black and grey broadband cable is correctly plugged into the back of your router?
Jon
