Ethernet d-link
LordRoy
When i plug in a D-Link connected with ethernet cable the Data led does not flash. How do i get this to work? Im trying to link ethernet to remote tv in another room.
11 REPLIES 11
Mustrum
@LordRoy  I suggest you refer to the user manuals if you still have them.
They appear to be quite old, but a read through the articles and videos on  a simple google search should give you the basics.
Many thanks to all those that have helped me try to solve my problem.
I have abandoned using ethernet d-links as i could not get the d-links to sync or pair.
I relocated my router so that i could hard wire the router ports directly to the TV and YouView box eliminating the need for d-links.
Regards Roy
