close
EE Wifi not working
Carrie2912
My Wifi has been in and out all day today, the wifi hub disconnects (red) tries to connect (orange) connects (blue) and then 10 minutes later does this all again, over and over all day today. HOPKINSTOWN PONTYPRIDD area.
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
