| For up-to-date information and comments, search the EE Community or start a new topic. |
17-09-2021 12:03 PM
can someone advise what type of SD card is suitable for the EE Hawk phone
17-09-2021 12:07 PM
17-09-2021 12:07 PM
17-09-2021 12:27 PM
link only tells me how to fit SD card not which type of SD card. Will any SD Type of micro SD card suit?
17-09-2021 12:32 PM
Any SD Card up to 256GB.
You can technically go higher than that but you need to Format it differently before using it in the Phone, another story.
