close
EE 4GEE WIFI MINI
LanceEssex
Hello I am trying to reconnect my Samsung Galaxy J4 to my wifi mini and it is asking me for a password which I don't remember how do I reset password
James,
I have purchased a EE mini wifi router when I registered it I was not asked for a password (just my email address and the number) and  so cannot log on to check my data usage. I thought that it may appear in my EE mobile account but it does not. Where can I find how much data I have left?
James_B
EE Community Manager
Hi @LanceEssex,
You can find your WiFi password underneath the SIM cover or on the keep me card that came with your router.
Hope this helps.
James,
wardi
Star Contributor
Star Contributor
Hi David610.. I can check my 4G router data via the router webpage 192.168.1.1 though you will need to access via the router password I suspect.
I can also find it in 'my EE' app.  If your phone is on your app homepage click the 3 bars top left and tap 'manage another product' as your router will have it's own phone number and account.
Thanks for help James it was on the rear of the unit
Regards Lance
