close
EE 4G Mini WiFi model E70 - Battery Information Request
Xr981
Hi.
I have an EE 4G mini wifi Model E70 .
Does anybody know if any other battery is suitable apart from an ALCATEL TLi021F7 , for instance an ALCATEL TLi020F1 or any thing else .
I presume it is dependent on the physical size and power input/output .
Very many thanks .
James_B
EE Community Manager
Hi @Xr981,
The EE 4G WiFi Mini batteries are not user replaceable. Please get in touch with Customer Care if you are experiencing issues with your devices battery.
EssexBoyEE
The battery in the E70 is replaceable but it's unique to that model, the other battery you mentioned is for the E120 which is thicker so it will not fit.
For reference both the Batteries will fit into the E120, but not the other way around only the correct one will fit the E70.
If I'm totally honest eBay is probably your best way forward here.
