close
Data used up within 4 days
Betsy2
Why would my data be all used up inside 6 days.
I'm on EE 8 months and it never happened before. I'm using the phone the same as always
7 REPLIES 7
Northerner
Hi @Betsy2
What does it say if you text BA to 150?
To contact EE Customer Services dial 150 From your EE mobile or 0800 956 6000 from any other phone. You can call Freephone +44 800 079 8586 on Skype
Betsy2
Hi  Northerner, it says I have 355 minutes and unlimited texts left.. doesn't mention data..
James_B
EE Community Manager
Hi @Betsy2,
Have you checked your phone's data settings to see which apps have used your data allowance?
Hi James, no haven't checked but nothing has changed and my data never ran out before ..
James_B
Hi @Betsy2,
I'd recommend checking the app usage breakdown in your settings to see which app has used more data than usual.
If you need help with this, please let me know which phone you are using.
Hi @Betsy2 ,
Typically it's a large and infrequent software update which does this. Recently I've also noticed Facebook and websites stream videos at around 256 KB/s in the background when I'm only reading text.
I highly recommend to search online to identify the option in the settings to view which apps have consumed your data, as has already been recommended.
In my case, it was Chrome consuming the bulk of my data in recent usage.
Android & iOS devices have a data counter within the connection settings menu that will give you an app-by-app breakdown of where your data & WiFi has been used - you can often set the counting period to match your billing cycle to further assist.
This will often identify the cause of increased data usage, otherwise check whether your phone's software updates are allowed to use mobile data or are restricted to WiFi only.
The vast majority of "where has my data gone" queries are answered by these two scenarios.
