16-06-2021 06:20 AM
I'm paying for unlimited data use, but I was thinking I maybe paying for lots of data I'm not using. I cant find out on EE web site the amount I'm currently using to compare.
Is it there but I cant find it or is it not there then how do I find out?
Regards
Crazyoyster
16-06-2021 07:28 AM
@Crazyoyster there is a section that tells you your average daily usage but if your on a unlimited tariff the chances are you’re paying for an amount of data that you’re not going to use.
If your average data usage is around the 20Gb a day mark then yeah unlimited data is ideal for you.
16-06-2021 08:39 AM
Hi @Crazyoyster,
What type of phone are you using? Most phone's allow you to track your data usage via your settings.
