close
Data Not working
Brandon28
9.4gb of data and 3 bars of signal yet websites and apps will not load
mikeliuk
Hi @Brandon28 ,
Have you turned on mobile data, does the phone make a data connection with the network perhaps showing "4G" in the top bar, and does your phone receive an IP address when checking in the relevant settings?
Have you tried turning airplane mode off then on (otherwise rebooted phone)?
