For up-to-date information and comments, search the EE Community or start a new topic.  |
03-02-2021 10:22 PM
I am trying to use an ethernet cable with my 4G wifi router. When I have the cable plugged in to one of the LAN ports, the 'LAN' light is not lighting up blue. Should it be lighting up?
If so... how can I make the ethernet cable work?
(I'm plugging the other end of the ethernet cable into a Macbook Pro via a thunderbolt converter.)
Thanks for any help!
04-02-2021 09:14 AM
Hi @AlisonBeck78,
Which router are you using?
Is your MacBook's internet connection working when plugged in?
04-02-2021 12:46 PM
04-02-2021 12:59 PM
Hi @AlisonBeck78,
If your MacBook was able to connect to the internet when connect via LAN, everything must be working as it should.
