24-05-2021 08:40 AM
Hi guys
I have connected an external HDD to my smart hub and I can't find it on my computer. How do I see it on my computer?
I have got network sharing turned on.
I am using Win 10 latest release.
It does show up on the smart hub itself.
Thanks in advance
Kriss 🙂
24-05-2021 11:51 AM
You need to enable SMB 1.0/CIFS File Sharing Support in Windows Features. Win 10 started disabling this sometime in its life.
@mikeliuk : Another red herring! You won't find this solution in any documentation.
24-05-2021 09:57 AM
How have you connected it?
24-05-2021 11:43 AM
Hi @SciFiKriss ,
It's likely you will want to refer to the manual for your smart hub or a relevant online reference document for it to determine how to access network attached storage presented by it. Its possible that in the GUI interface you may find links pointing you to help documentation that will assist.
24-05-2021 11:46 AM
I have plugged it into the smart hub USB port. The hub sees it when I go in there it is just the computer that doesn't 🙂
24-05-2021 11:51 AM
24-05-2021 11:58 AM
Hi @SciFiKriss ,
Please see below regarding configuration on the client. You should verify what the protocol is being used on the server so that you don't end up tweaking irrelevant options for a different version which is not used.
24-05-2021 12:01 PM
24-05-2021 03:41 PM
Thanks! You're welcome 🙂 ! Glad I could be of assistance & it is now sorted.
