on 27-04-2020 04:53 PM
im currently just on a sim contract and wanted to know how I can change to a phone and sim contract ?
Solved! Go to Solution.
on 27-04-2020 05:10 PM
Hello @Tegan2
If you login to myEE (using the same details as you've registered for the forum), there should be an option for "upgrade". If you click through there, it should take you to the online shop where you can choose a phone and plan.
Hello @Tegan2
