close
Change security settings as iPhone won’t connect to my mini WiFi
Joewindowsetc
How do you change the settings on a mini WiFi if you only have an iPad and can’t plug it in via a usb?
Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the password found under the battery cover. Then on the WiFi Settings tab try changing the WiFi to:
Security = WPA2 PSK
if it's not already, as it should be.
