close
We have to reset the bright box every day?
starlight-party
I am hoping someone can help please.
for some reason every day our bright box ( fibre ) has to be reset/rebooted.
the ping is poor(80/150) as are the download speeds (10mb/15mb).
once the router is reset everything is fine again ping 12/18 and speeds 60/67mbps.
so I know this is a line issue, it’s a router issue. Problem is every time we reset the router our sky q boxes can’t connect to the router, no ip and we have to reset the settings and start from scratch.
Could this be an issue with the router it’s about 8 years old?
thanks
What makes you want to reset your router?
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
