Cannot log into admin on 4GEE hub
Kieranc67
Last night i logged into the admin on my router to change my NAT type. I logged in with the generic “admin” password then changed my password when logged in. I tried to log back in today and now says the new password i made is incorrect and when i try “admin” it says this is also wrong. Can someone help me with getting logged in please. Thank you
6 REPLIES 6
Factory Reset the router & use the admin username/pwd as "admin"/"admin" or you'll find the admin password under the battery cover.
Where is the reset button? I read that it is on the bottom of the device but have looked all over and cannot find it
I have found it now. Thanks for the help
Another question i also had if possible to answer. Can I purchase LTE antennas for my router from anywhere or do they need to be from EE to work with the router as i have poor signal where i am
Thanks! You're welcome 🙂 ! Glad I could be of assistance
Every time the web page logs me out from the router settings and then i type the new password in it comes up saying incorrect password then i need to reset my router again
