close
Cannot but add ons for my 4Gee WiFi device from my iphone
Waynem
Hello
i have credit available but am unable to top up data on my pay as you go 4Gee WiFi device. WiFi is off when I log on to my EE and the add on page but I just get a turn your WiFi off message or use an ee mobile which I don’t have. Any ideas?
the app doesn’t work either.
7 REPLIES 7
Leanne_T
Hi @Waynem
Are you connected to the WiFi device when you visit add-on.ee.co.uk?
Thanks 🙂
What does http://add-on.ee.co.uk/purchase from a device connected to it by WiFi offer you?
Going there from a mobile phone with its WiFi turned off will only be trying to buy data for the mobile phone, not the mobile router.
I have a similar problem, although I can't connect to the EE WiFi router because I purchased it for someone that lives 30+ miles away.
The account has credit, which I have purchased, but there must be a way to buy a data add on without having to drive there and connect to the router?
Hi @chr156r33n,
Welcome to the community 🙂
If the device has credit on, you can ask the person who has the router to follow the instructions given by @XRaySpeX above.
Alex 🙂
I would, but this is for my 86 year old Nan who is using a Facebook Portal.
Is there no other method for doing this? It seems frustratingly limited.
Hi @chr156r33n,
To do this yourself you would need to be with or connected to the device you want to add data to.
Alex 🙂
Can someone help me understand why I can top-up someone's credit from anywhere but I have to be within WIFI range to change that top-up into data for a product that does not function without data? This effectively makes the product useless for this purpose and means that the credit already purchased is a non-refundable waste of money.
Surely this is a mistake?
