close
Bunny ears antennae for router
rawlins220444
Can anyone advise me about bunny ears antennae for my EE router. It is the smaller of the two routers available and am told it is made by Alcatel. The terminals are TP9 so antennae with the bigger SMA thread connectors will not fit.
James_B
EE Community Manager
Hi @rawlins220444,
Sorry, we don't stock antennae in our accessory shop.
Have you tried searching the web for stockists of an antenna with a TP9 connection?
Yes found these https://www.amazon.co.uk/Performance-Amplifier-Reception-Receiver-Hotspots/dp/B074GZSX5Q/ref=sr_1_14... but they don't have screw on connectors
Sent from my iPad
James_B
Hopefully another community member will be able to recommend a suitable antenna for you @rawlins220444
Good luck with your search.
